Engine choice for '72 project? - help me decide
Southern Colorado
Very quick backstory: I have a restored '78 FJ40 that I have owned for 36 years and know FJ40s pretty dang well. I love stock (or close to it) for many reasons, but added TBI EFI and power steering to my '78 and it's a fun driver. I also have an '89 FJ62 (3F-E) I have owned for years. Love the EFI.
I now have a '72/'75 project FJ40 that needs an engine. I practically have two choices: install a rebuilt '81 2F (carb'd/stock) in my garage, or use an '89 3F-E and hacked-up wiring harness and computer/air filter (MAF). I won't do an LS engine.
I'm retired and have the time, but I'm dreading trying to install the 3F-E, due to the lack of complete 'how to do it' info on the web, and having to dope out the harnesses and relays and cut down the excess harness. I'm also missing all the fuses and relays in the 3F-E harness fuse block. Grrrr.
I'm *this close* to just selling the 3F-E and plopping the '81 carb'd engine in there, to shave a lot of time/agony off the project. I can always add AFI TBI to the 2F later, if our modern gas makes it undriveable.
Am I nuts? Should I buckle down and figure out the 3FE method, or just get 'er done with the 2F and move on? This truck won't be an all-original high-dollar job - it will be a driver with an FST, and that's pretty cool right there. This FJ40 has been a project since 1988 and is comprised of many trucks and parts. I have a lot of other un-fungling to do, to get it right and Toyota-like, so the whole job is not just an engine swap.
Thanks for your unfiltered advice!
Steve
I just love the simplicity of the F/2F engine, adding a complicated system to it just goes against the grain. A bare-naked de-smogged 2F is a thing of beauty when stripped of all the government mandated and "convenience" nanny stuff that gets in the way. Elbow room under the hood, the ability to get a wrench on a certain nut is priceless. It saves much time and agony. I got rid of all the VSVs that probably didn't work anyway and all their vacuum lines. My 10/'73 carb came with a "throttle positioner". I'm sorry, my right foot is the only throttle positioner that I need so I removed the factory gizmo and it's vacuum line. I'm down to 2 vacuum lines off the manifold, 3 if you count the vacuum gauge.
There's a fairly wide variety of carbs, manifolds and dizzys that you can fit. I run the earlier, big, F starter motor because I like the sound better. I like the the big cap 60 series dizzy so i run that. I don't think I need an oil cooler and it gets in the way, so I don't run one. I don't trust vacuum secondaries so I run an earlier carb.
Run that rebuilt 2F as is, modify it as you go along. Simplify.
I am consistently under-impressed with the 3FE…and…I am consistently impressed with the desmogged 2F in the earlier 40s. So much so that I will eventually put carbureted 2Fs in Ruftoys and the blue 45.
If I were to do it again, with gas, I really like the 1FZ.
Who doesn't really like the 1FZ? Probably the best straight six Toyota ever made. Not a bolt-in install though, probably more complicated than just EFI.
I might do a Cadillac 500, or a Mercruiser, or a 454, or a big block Pontiac, or a Jag V12 (all been done). But I'd keep the 2F(ish) Pig, just in case.
Only the two choices here.
Having not done it, I'm taking out my rear, but ditching the toyota engine management wouldn't be any different than an LS swap.
I'd do the same with a 3FE.
Why run the outdated Toyota garbage when there's far more precise options.
I vote with the majority: desmogged 2F. You've got the best of the 2Fs right there with the better head, lighter valve springs, modern dizzy. Order a new Toyota world carb and new mechanical fuel pump for it and it'll run trouble free for decades: the most complex electronic being the idle cut of solenoid on the carb. You'll have your apocalypse truck in the garage waiting for you to fire it up any time you need it.
