I'm going through my emissions equipment (on my '83 fj60), and I had a couple questions. For the record, I had slightly high CO, then pretty high NOX, when I replaced the EGR modulator and EGR VSV. A bonus, it seems to clear up that "it sometimes runs horribly at stoplights when it's hot" thing I sometimes have.
[STRIKE]1. The VTV on the left side of the engine that's before the distributor diaphragm--is there a problem if that is the blue VTV instead of the brown VTV? Because that's what I have (blue one side, black the other). What's the difference between the colors, anyway?[/STRIKE]
4. The lines to the distributor main diaphragm and sub-diaphragm are switched. Is that a problem, and what would be the effect of this?
Bah! Missed the thread with the answer.
[STRIKE]2. If the blue one is OK on the left, is the blue side supposed to replace the brown side as far as its orientation? The picture shows the brown side facing the diaphragm[/STRIKE]. Also answered in the linked thread.
3. The emissions FSM says that the VTVs should have a "restricted" flow in one direction. I have no flow in that direction; is that acceptable?4. The lines to the distributor main diaphragm and sub-diaphragm are switched. Is that a problem, and what would be the effect of this?
