I am going through emissions here in Arizona in March, so sometime in mid to late february I am going to do a tune up. I had problems last time so I hope not to have any this time. I hope to be more proactive. I was searching through some past post and have a few questions.
1. I will replace my plugs, wires, rotor, air filter, fuel filter and do an oil change w/filter. Is there anything else I should replace?
2. I did a search for seafoam and would like to do that before I do the above. I just want to make sure I do this right.
2a. Put a can in the gas tank, do I need to drive the whole tank down before I change the plugs?
2b. Second, put some in the intake hose that goes to the PVC valve, I think I saw someone said about a cup. Make sure the engine is hot before I do this. Put it in and it will stall, wait about 10-20 mins and start it up and drive around.
2c. Put some in the oil? This one I would like some more clarification on. How much to put in the oil? How long should I drive it with the seafoam in the oil? I do burn some oil.
Thanks for the help! I hope to do more good then harm
Sean
Sean
