For Sale Elizabeth, NJ - 2005 GX470 155k Miles - 2nd Owner
Year
2005
  1. GX470
Elizabeth, New Jersey United States
Mileage
155000
Color
White
Hey guys. I have a 2 owner (I am the 2nd owner) GX470 for sale with full Lexus dealer service history (can verify on the lexus website) up to 125k miles from the first owner. I am moving out of the country next year for greener pastures and we are only going to keep my girlfriends beater car when we come back to visit. Currently sitting at 155k miles, it has been driven less than 5k miles per year since I got it in 2018 (I work from home and mostly use my girlfriends hybrid).
Maintenance Done In the Last 2 Years:
[Work Done - Some By Me, Some By Shop]
New Rear Calipers
New Front and Rear Rotors
New Front and Rear Brake Pads
New Front Caliper Lines
New Struts Front + Rear
Air Suspension Delete
New Inner + Outer Tie Rods
New CV Axles
New Axle Seals
Front Wheel Hubs (Bearings) from a 40k Mile donor
Rear Axles and Hubs Swapped from 40k Mile Donor
Rear 3rd Member Swapped from 40k Mile Donor
New Upper Control Arms + Ball Joints
New Lower Control Arms + Ball Joints
New Front Sway Bar Links
New Front Sway Bar Bushings
New Rear Sway Bar Links
New Rear Sway Bar Bushings
Passenger Side Speaker Fixed
New Battery
New Serpentine Belt
New Power Steering Hoses
New Alternator
New Exhaust + Muffler
[Mods]
Sea Sucker Kayak Carriers (can haul 2 kayaks)
Remote Starter with 2 Fobs
Toyota OEM Tow Hitch (6500lb rated) + Wiring Installed
Front Bumper Bar
Front Bumper Bar Lights
GROM Bluetooth
[Wheels]
TRD Wheels With 265/70/17 Tires + TPMS working + OEM Spare with matching tire size
[Fluids Done Recently]
Coolant using OEM Toyota Long Life Pink
ATF using OEM Toyota Type IV
Front and Rear Diff Fluids using Mobil1 Synth
Power Steering Flush and Refill With Toyota Type IV ATF
Chevron Techron (done once per year since I bought it)
[Parts Not Yet Installed - Included]
Few spare bottles of Toyota ATF IV
All OEM Manuals
8x OEM Spark Plugs
2x OEM Rear UCA + Bolts + Washers
2x OEM Rear LCA + Bolts + Washers
Reman Front Calipers x2
OEM Ebrake Lines x2
Front CV Axle
[Issues With The Car]
Car is almost 20 years old and could definitely use a paint job. Typical blizzard pearl paint issues, has chips and peeling around the windows and roof. I tried to patch up the peeling paint but new spots came up and I finally gave up this year. Front bumper has a scrape because I suck at driving in NYC garages. Rear bumper has a spot from backing into a sign. No body rust aside from a little bit on the door jamb near the floor on the driver door, which gets sprayed annually with woolwax to prevent spreading.
Dashboard cracking issue, though its better than most I've seen as I use protectant on it regularly
The eBrake not working (had to drill out the cable mounts when I was installing the rear hubs + axles), but I am including the new OEM cables.
Front Passenger CV Axle developed a tear after driving over some debris on the highway recently. A new CV Axle is included with the car and should be an easy swap or an hour job at the mechanic, as the entire frontend was rebuilt not too long ago and should not be rusted together :')
Car drives like a dream and I would take it with me and import it if I could, but the country I am going to does not allow you to keep imported cars longer than 2 years.
[Price]
Asking $14000 OBO.
[Pics]
Pic Dump:
Underbody pic dump:
