Here are some of my many symptoms, all of which appear to be random and occasional, nothing repeatable yet.
I've measured the battery with a Fluke DMM, it's 12.4 at rest and when cranking is 11+, so it seems to be able to supply enough cranking current. I can take it in for testing, but since the voltage doesn't drop below 11 during cranking (as far as I recall) it doesn't seem like the issue. And in the no-start / no-dash lights condition, I would think that even if the battery were low that I would get some sort of lights. I've wondered about the ignition switch, but don't see how a faulty switch would cause the voltage to the winch to drop so much that it resets.
Open to any suggestions. In the meantime, I'll probably start unplugging things like the winch itself, LED fogs that replaced the factory fogs, etc.
- Remote lock/unlock not working.
- When turning the key to start, I get nothing, no lights, no cranking, nothing. A few more tries, and it kicks in.
- While driving, if the headlights turn on, I get all dash lights (ABS, ATRAC, Battery?, etc.) - maybe I should take a picture, but I've been driving... Oh, and at the same time as the lights on the dash, my Stereo Head Unit will turn off and then finally reset. Not sure if it's the Battery power or the IGN signal that's doing that.
- Turning on the headlights causes a quick dip in the dash battery gauge, but it returns. But my Radio HU resets. Very Odd. Turning on my 20" LED light bar has no effect.
- After it starts, my winch beeps at me complaining that it needs to pair with the remote, which tells me that it lost power some how.
