Electrical gremlin with 7 prong teardrop trailer hooked up
Just bought a teardrop trailer, with trailer hooked up remote for power locks will not work & ac continues to run with ignition off, ac stops when I unplug trailer. I tow boats all the time without issue, even boats with trailer brakes. I bought the trailer from an individual that towed with a Cadillac & never had a problem. Is this a LC problem? I called the trailer manufacture but they had never seen this. They did say possible voltage regulator on the truck. Help appreciated.
Yes. I have the same issue with my 2004. But only with my sled trailer. I think it has something to do with the trailer battery back feeding. Sorry, I don't know what the fix is. I just got into the habit of unplugging it when I parked.
I thought the same thing about diode, trailer builder says that's not the problem. thanks for the suggestion.
Easy to troubleshoot...do you have the same issues with the trailer battery disconnected??
Steve
We have discussed that issue and a solution a while back in a thread here
I did a search to no avail e9999, don't need or want negativity, supply something positive or don't respond.
so I'm trying to help you by telling you that this is a known issue with a discussion and solution that can be found in the forum, and that's negativity? All right then...
As I said, I tried searching, probable user error, supply a link would be positive. Thanks for responding.
