For about the last 8 years, my 1969 FJ55 has had turn signal problems. It used to be that the 5A fuse would blow at random, sometimes every time I drove it, sometimes only once every few months.
Then it got to the point where whenever I had the fuse in, the stock ammeter would always get higher than normal. Now if I pop in a fuse, the ammeter goes way down with excessive draw. Go to switch the turn signal to either way and the right blinker stays on and solid (no blinking). Before this, it would only get stuck on the when switching to the right.
I'm going crazy trying to track down the issue. The turn signal indicator under the steering wheel has been replaced not to long ago (piece of brass got worn and broke inside), and the entire front half of the wiring loom is new (lit on fire at Pismo, hot ignition wire shorted inside cab and melted everything).
So where would you look? I'm so confused.
