I am still unable to connect the vacuum hose from Port Q of the EGR vacuum modulator to the EGR valve without the engine idling roughly.
According to the emissions manual, above 2500rpm the EGR vacuum modulator should apply enough vacuum to open the EGR valve.
Here's the issue. There is a small amount of vacuum at low idle at Port Q that opens the EGR valve enough to cause a rough idle. I am running the cruiser now with the EGR disconnected and am getting some slight hesitation and bucking when I change RPM's at highway speed.
Note- that I have already replaced the intake/exhaust manifold, gaskets, carb insulator and vacuum hose with new OEM parts. I am pulling a neg 18 on my vacuume guage at idle.
Also, I suspect I may have a dying brake booster, as when depress the pedal, I lose some vacuume pressure and the pedal will progressively get softer. Brake fluids are at right levels and not leaking.
Any thoughts?
Any thoughts?
