before I post on one of the main tech boards I wanted to get y'alls opion on ball and claw axle shafts. i just tore open my saxles in order o rebuild them and upgrade a few things and found that they are truely as old as my truck. the axle has disk brakes so I was hoping that someone had swapped a newer axle under my 64 lv but unfortunately that is not the case.they just put on some sort of disk brake setup.
so my research tell me I cann't put a birfield axle into this axle housing due to the ball and claw haveing a ushing and the birfield having a wider opening for the seal.way to much effort to machine out enough room for a seal. so do i leave as is or do I build up a new front axle. I have a line on a housing and some mini truck knuckles i would just need to source out a fj62 4.11 diff and I could get it together pretty easily. but just want to make sure it is all worth it.
thanks Jason
thanks Jason
