easy seat upgrade for troopies and others
land of enchantment, at least for now
If you are still sitting on uncomfortable stock seats, you might be interested in this.
For the later 40-series tubs with the fuel tank under the floor, I found a super-easy seat upgrade. In my 1980 rhd troopy, I replaced the stock split bench with buckets from an Isuzu Rodeo. The dimensions are as close to bolt-in perfect as you will find--I had to bend the front mounting tabs a little to reach 90* and I oblonged all 4 holes a couple mm. My tub did not have the inner rear captive nut for the passenger side seat, so I had to deal with that, but otherwise it was really simple.
After a 2-week, 2600-mile road trip, I must say it is a huge improvement over stock. Ideally, the front of the seat would sit a bit higher (or lower in the rear) for more leg support, but it it still better than stock. And since it is rhd, I am sitting in the passenger seat which has less wear than the driver seat.
Here is a pic of what the seats look like, I didn't get any of the install.
