Good day/ evening,
I acquired an early h41 with the 5.3 1st gearing. It has a 10-spline output shaft which allows it to mate up to a 3-speed transfer case without modifications. The inside appears very well with no obvious wear. Unsure if it has all the bearings, but I assume it does since everything spins freely with no obvious play. It's missing gaskets and seals; wondering if anyone has a lead on where to get a correct "rebuild kit" or source out some parts as I understand these are a rare breed.
Man-a-free shows a transmission overhaul kit for fj40/fj60 4-speed transmissions that cover the years from 1958-1989, but I'm unsure if that would be right as I assume the gaskets/bearings/seals changed over those 30 years when Land Cruisers converted from a single piece to a split transfer case as well as the transition between h41 to h42. Thanks for the help
here are some pics:
here are some pics:
