Dynabeads
Chester,vt.
I am about to mount up my 37x12.50x 17 IROKS. Anybody have Dynabeads? How do they work for you?
I have them. They work great. So much better than weights. No more knocking them off is a plus.
I'm not sold on them. They had a chart for how much to use and IMO were way off. I ended up removing most of them and then finally going with a traditional balance.
I have a tub of beads and a digital scale you can play with if you like. Just send me your address and I'll mail them over.
Works great
I have 10" rims w/ 13.5" tires and I went by the chart which was 8 to 10 oz. and I've been happy.;) If you use the standard spin balance and the lead tape on weights it's only good until the tire spins on the rim. If you run beadlocks thats not a problem, but then you cant spin balance them either. :meh:
I run airsoft bbs and they work great, as stated much better than weights.
I tried the airsoft pellets in the LTB's, didn't help at all. That said I'd try the Dynabeads and see
what they do.
what they do.
my ltb's on my 4runner rode like tank tracks untill i put in the dyna beads after that it was perfect
You can have beadlocks balanced with those sticky weights, right?
I ran airsoft bb's for a while and they were pretty good. I went a bit over the weight spec on the dynabead website and only got a couple of vibes at 65+. There is a shop near my house that does spin balancing with dynabeads or the equal balancing product. That would be the best option since they can fine tune how much each tire needs.
