FWIW, I did the duplicolor about a year and a half ago. For $40, I have no complaints. I used a loop-nap (technical term
) roller for everywhere I could reach and a rattle can for the crevices.
My prep:
1. cut out rusty metal and weld in new.
2. remove as much old paint as possible (I probably got about 75% bare metal) with a knotted wire cup on my angle grinder.
3. soak all seams with rust killer (can't remember the name right now). Use the stuff in a bottle that you can brush on and work in. The spray cans suck donkey nads.
4. soap and water thorough cleaning.
5. Jasco metal-prep, let dry overnight without wiping off.
6. (only if your garage is as dusty as mine) blow all the dust out with the air compressor and an exhaust fan to keep it from re-settling.
7. spend a couple hours rolling up masking tape into little cigarette butts to plug all the bolt holes in your tub.
8. roll, spray, whatever.
9. go outside and get some fresh air
I have had it peel up in a couple places. I used sticky weatherstripping under the tranny cover and when I removed it recently, a couple little spots of the duplicolor came up with the weatherstripping. I scraped, sanded, and resprayed the spots with the rattle can. Also, in a couple spots where I couldn't get all of the original paint off the floor like under the heater, I think the duplicolor causes the paint to bubble up. The duplicolor was pretty solid, but the underlying paint made a big bubble. Same scrape, sand, re-spray.
Considering how much abuse it sees and how much gasoline I've spilt on it recently, I'm pretty impressed.
Good luck,
Eric
My prep:
Good luck,
Eric
