DUI Distributor
MilkyWay
Hi all.
Im getting my engine remanufactured and currently thinking of putting a DUI distributor as an upgrade.
Nothing wrong with the original distributor.
I guess my question is is it worth doing this kind of upgrade?
Does anybody have any experience with this particular brand?
Any input is welcome.
Thanks in advance...
I am about to be in the same position and decided to stick with my stock distributor with my aftermarket Jacobs Omni coil. A aftermarket coil will help get a more consistent spark.
sell ya mine for $150
They DUI distributor fits differently and you have to make sure they engage the oil pump properly so your engine gets oil.
MANUCHAO said:
Sportbiker,
Why you selling it ?
Had no use for it? did not like it?
Thanks
just put all oem ignition back in.
MANUCHAO said:
Hi all.
So replacing the waterproof, ball bearing, remote vented, remote coil distributor with an all-in-one unit with an undersize coil that gets hot, non waterproof construction, only a single cheap ball bearing on the shaft, is an upgrade?
That's good marketing on somebody's part.
Can I have that crappy old Denso distributor & coil when you're done?;)
If you want to upgrade your ignition (& it all works) a big coil is the cheapest way. Then you can open up the plug gap.
Another note on going to another dizzy, you'll lose your altitude compensating advance.
