DUI distributor with no vac advance?
Twin Cities, MN
Hi all--Asking in the 40 forum for more visibility:
I just bought an FJ55 that someone began converting to fuel injection using the AFI kit. The truck has a DUI distributor installed but the unit has no vacuum advance and instead a 6-ish wire connector that was running into the AFI wire harness. Fully electronic spark timing here? I am not finding much information searching as most DUI threads seem to mention the vacuum advance version.
What do I have here? Is this thing usable without fuel injection? I ask because I am seriously considering going back to the 2F carb (and potentially stock distributor, depending on whether I could use this one or not).
Apologies if this is well-covered territory, perhaps I am not using the right search terms.
Thanks.
It’s the modified DUI that comes with the AFI.
Only usable with the AFI
Aha, makes sense. Thanks for the insight.
Your tbi injection advances and retards the timing , so you’d use a distributor that has all the timing features removed.
