Driveshaft angles
Colorado Springs, CO
Website
www.mntoyx4.com
When using a standard non-cv driveshaft, you want the t-case output and the pinion flange to be parallel to each other correct?
So if I were to use an angle finder and measure the angle of the t-case flange, and the pinion flange I should be able to figure out if I need to add shims to the rear leafs am I right?
I'm using some large shackles in the rear (2" over stock) and have some vibes in the rear end. I'm tearing apart my suspension this weekend and this would be a good time to add in shims if they are needed.
Does anyone know if there are any chain parts stores that carry steel shims (not aluminum)?
Thanks!
curious1 said:
Unfortunately I did not leave myself enough time to order them anywhere buy local. I totally meant to get this done weeks ago, but I've got a shop and some people lined up for saturday to get a lot of stuff done.
