Driver side reared sag...
Hey guys,
So I just clicked 190k miles on my Landy. I noticed about 2 months ago a slight sag on the rearend on the drivers side. It's only noticeable from the rear end. Recommendations? One mechanic told me to consider air-up shocks? Is it just shocks issues or you think a spring may be shot? Thx
If the springs are original, replace them. Maybe tighten up the t-bars a bit. After that if it's still not level, you can use trim packers to even out.
Adjust your torsion bars to eliminate the sag. It's not uncommon to see the left rear sag.
^This. Not sure why the mechanic didn't just suggest adjusting the torsion bars, maybe he's not familiar with them. Although they're on the front, adjusting them properly will likely level out the rear end. Don't forget to do an alignment after tweaking anything front suspension related.
