Need some suggestions guys...
I've picked up a bad driveline Vibration on the 80. Starts around 25-30 mph, and only when I'm on the gas. If I'm coasting - nothing. Light throttle - some vibration. Heavy throttle - heavy vibration.
It doesn't change significantly with engine rpm when the transmission shifts.
I've gone under the truck and yanked on both ends of the drive shafts - couldn't feel any play.
Checked the front wheel & trunnion bearings - a little play in the left front wheel bearing, which I fixed ... No change.
I've looked the tires over and don't see anything, but I'm going to take it in and have them rotated and balanced. Though I'd expect that kind of problem to show up when coasting as well.
Ideas?
Ideas?
