Has anyone gives you an answer on this?And which fluid and how much do we need for full flush?
I am about to do this myself.
Use Toyota brand fluid. I think it’s like 3 or 4 quarts.Has anyone gives you an answer on this?
How many of those? Get's priceyUse Toyota brand fluid. I think it’s like 3 or 4 quarts.
How much is that in Standard speak?Use Toyota brand fluid. I think it’s like 3 or 4 quarts.
1 quart is 946 ml.So 1 quartz is 354ml?
Same here. I flush a bottle of that Valvoline Synthetic through all four corners once a year if not more often. Been using that fluid on my 100 for 11 years.been using this stuff in all my Toyotas for over 10 years, with great results. its cheaper, and comes in quarts. I flush my Brake fluid once a year. I know it's a bit excessive. but .. i guess thats me
forum.ih8mud.com
I must read all the posts so many times and yours is the easiest to understand. Should I suck out the old fluid I. The master first would that helps and how much fluid do you think is in the accumulator? I don’t have a scan tool but some debits a closed system and I’m not disturbing abt components it should be ok, right? Thanks a lot!Only one good way to clear/clean out the reservoir tank; With IG key ON, hold down brake pedal, open a rear caliper bleeder.
Once reservoir very near the bottom. Close bleeder, turn off IG key then pump brake pedal 40 times (empties accumulator).
Accumulator dumps fluid back into to reservoir as you pump brake pedal with IG key off, to about level seen below.
Now add new Toyota brake fluid, doubling the amount currently in reservoir. (50/50 mix of old and new)
Now again clear/empty reservoir though rear bleeder. Repeat this 5 times.
After above flush, keep reservoir above low line at all times.
Now move to other rear, for a short flush of its line/caliper.
Now move to FL, pump pedal 20 times IG key on. IG key now stay on until done.
Hold down pedal and open FL bleeder. Close bleeder and then pump pedal 5 times. Repeat 10 times. Only needing to pump pedal 5 times between each bleed., after the first 20 pump.
Never release brake pedal until bleeder closed, or air is suck in to caliper.
Now move to FR (front right). Bleed it, a minimum of 7 times.
Torque bleeders to 9 to 11ft-lbf. Blow out bleeder with brake clean (straw) than add WD-40 (w/straw) and cap them.
I use a minimum of 5 Toyota bottles, maximum 7 bottles. How many bottles depends on how much used to flush accumulator, the more the better. Also if caliper piston clasped, to get max out of calipers.
So after reading @2001LC posts, I’m convinced that he’s right about flushing and to be safe with OEM Toyota. In 2019 I had a brake light and eventually replaced the brake assembly $2800 plus labor. Research the invoice, the shop used Liq Moly, and 3 years ago I had another shop flush it for $300 so I was going to let them do it again and finding out unknown fluid? So may as well do it myself for less than $100. If it’s not because of the high cost I would use other brand but I don’t want to replace this expensive part anymore so to be safe I’m using Toyota. However, I was having problem locating the OEM fluid! My local dealers Longo largest in US does not stock them. No sure what they are using, a lot of out of state dealers have them less than $10/12oz but will not ship to California. Luckily I found this small dealer in Manhattan Beach got them at good price and one shipping charge regardless of quantity so I ordered a dozen. Hopefully if I don’t open it will be still good on the shelf.How many of those? Get's pricey
I ordered 3 not sure if will be enough. Probably need 5? I haven't done this yet.
