Door Window Rubber Trim Gaskets (1 Viewer)
S. Jersey - New Germany
I've noticed much of my rubber trim gaskets on my door windows is all starting to shrink and come up off it's molding. Can they be fixed or do they have to and can they be replaced?
I just replaced all of mine. I picked them up at cruiser parts. theyre easy to do so don't worry about it. just roll down the window and pull up on them. remove any broken tabs still in the door. the new belt moldings come with clips. once you look at the door where they clip in its self explanatory...
How easy is it to install the ones on the rear quarter windows? Just as easy?
Yes they just pop off. Only the one's from the front doors are a little more work because of the mirrors. You have to loosen the mirror to get to the trim.
yes, I should have remembered the mirrors.
OP, theres a write up somewhere here on mud...
WHAT! $50 apiece? There got to be another way.
I just did ALL of mine and then did all the window felta you can et them still oem well worth it in opinion shes a beast but all the little yhings are tightened up
