My belt mouldings were in sad shape from sunlight and maybe a hailstorm, and just plain aging.
It is great that Mr T still sells replacements, albeit a little expensive. They are just north of 50 bucks each, but they are available.
I searched and found a few threads with part numbers, and replies about how easy it was, but no instructions with pictures.
I bought the parts and studied them before I tore mine out. The new belt mouldings come with new plastic clips, so I didn’t have to worry about breaking any of them.
I started with the passenger rear to get a step up on the learning curve. I started near the middle, and it looks like I would have had even better luck starting toward the front end of it. The clips have a springy side and a fixed side. I pushed the moulding toward the window glass and pried up to get it off the clip. They all pretty much broke anyway, but it didn’t take as much force to break them this way.
I rolled the window up just a bit to protect the felt trim at the top of the inside door panel. I used a big plastic prybar from a kit I have for pulling dashes and trim off.
When I had the moulding removed, I was left with all the clips still in the door exterior panel slots. I used a knife and the red prybar to release the latch and lift the clip.
