SERVICE HINTS
W3 WIRELESS DOOR LOCK ECU:
1−GROUND : Always continuity
8−GROUND : Always approx. 12 volts
13−GROUND : Approx. 12 volts with ignition SW at ON or ST position
D21, D22, D23, D24 DOOR LOCK MOTOR AND DOOR UNLOCK DETECTION SW FRONT LH, RH, REAR LH, RH 2−GROUND : Approx. 12 volts with door lock motor at lock operation
3−GROUND : Approx. 12 volts with door lock motor at unlock operation
B4 BACK DOOR LOCK MOTOR AND BACK DOOR UNLOCK DETECTION SW 2−GROUND : Approx. 12 volts with door lock motor at lock operation 3−GROUND : Approx. 12 volts with door lock motor at unlock operation
I19 (A), I20 (B), I21 (C) INSTRUMENT ECU
(A) 3−GROUND : Continuity with front passenger door open (A)14−GROUND : Continuity with driver door open
(B) 1−GROUND : Continuity with rear RH door open
(C) 7−GROUND : Continuity with rear LH door or back door open (C) 1−GROUND : Always approx. 12 volts
(C) 2−GROUND : Approx. 12 volts with ignition SW at ON or ST position (C) 4−GROUND : Always continuity
D14, D15, D16, D17 DOOR COURTESY SW FRONT LH, RH, REAR LH, RH
1−GROUND : Closed with door open
B2 BACK DOOR COURTESY SW
1−2 : Closed with back door open
