IOT get the piston within the 40-50 thou head clearance that provides an effective quench area, you have to have a zero'd deck (flush with the piston top at TDC) and a gasket that is no more than 40-50 thou thick once compressed (or some other combination with the same effect).
The gasket that came off is 62 thou compressed, which is too thick to provide the "squish" that is effective in controlling detonation when you raise the engine's compression. It maybe that there is another OEM or aftermarket gasket that compresses to less, but I'd rather not buy every possible one, then mic it and see if it will compress to 40-50 thou, hence the question does anyone know of a brand that is thinner.
When I built my Vette engine a few years back, I was able to get the quench down to .039 using a Cometic gasket at .027. That engine runs pump gas on my annual trip to Florida at sea level with no ping and a static compression ratio of 11.37:1. Quench is a good thing and I would not want to raise an engine's C/R much beyond stock without a plan to get it.
