Does anyone make a FULL suspension bushing replacement kit?
Snoqualmie, WA
Website
raincitysupercars.com
My '99 is doing OK and even has very low miles at 120k, but spending all of it's life in Florida before coming to me in the PNW has left noticeable dry cracking on all the suspension bushings. As a winter project I'm going to give it a full suspension overhaul. Is there any vendor out there who simply makes a suspension overhaul kit for the 100? I've been looking at the usual sources, but seems to be a bit of a piece here and a piece there kind of thing.
Nope.
And just a recommendation, it may cost more, but I'd go with OE bushings on most suspension bushings. Check front arms, rear arms (might just be cheaper to replace w/ aftermarket), check bushings on front diff, rear track bar, and any other rubber on your way that looks worn, if it's bad enough you can check your body mounts. Aftermarket poly bushings are good for sway bars (I'm running or rubber, just as good) and steering rack bushings.
