ShottsUZJ100 said:I hear ya, though I think I side on my locker installer's opinion (no offense) combined with the fact the 100's powertrain is notably upsized in torque compared to the 80. My installer said that because the gear was thicker (more area and mass the better) and it had more splines (another plus), and the fact they had 80 gears there to compare, that their opinion was the 100 gear was notably stronger. Who's correct? Who knows.
Uhm, the gears do not have splines (OK the pinion does) So that is irrlevant. Both Carl and me used the Toyota axles with 32 splines. So no loss there. Also Carl works for Randy's so I figure he pretty much knows what he is talking about as well.
I have no problems running the 80 gears in the rear. Carl's way is pretty elegant and good thing he got to it. I think the way he did it for the E-locker axle is well worth doing, since you only need some additional parts. Just think about the "install kit" costing a little more.
The tickness of the gear is not going to matter much since it also gains strength bolted to the carrier. Also 80 gears uses a bolt and nut to secure and 100 gears use a bolt into the gear. So, what is stronger there? It is all speculation at this point. Bottom line the benefit of regearing far outweighs the possible introduction of a slight weakness.
Is it better to have more wheelspin and have more stress on the whole drivetrain, then to crawl over the same obstacle. I will take the gears anytime.
I have never seen a 80 rear diff broken. Not even with 40" tires etc etc. We have broken just about any other part, including rear 80 series 30 spline axles shafts, but never the diff (in particular the ring and pinion). Also you are more likely to snap the pinion shaft and maybe Carl did measure both to compare.
