Diesel Mechanic
Awe don't do it. Not another 6.5 haha. What are you having problems with. I don't typically ever work on GM anything because it always seems to be a PITA.
Thanks for the input, but your a little late, I'm like 98% done, I just cant get it to start, but I'm sure it's just some little thing I'm missing.:bounce2:
Should only require power to the injection pump to run. Have you bled the fuel system?
That is perfectly normal. It's also perfectly normal for these engines to throw rods left and right.:grinpimp:
Like previously stated, with minimal electronics your issue is probably going to mechanical. Make sure fuel is being provided.
it's out of a 1995, so it fully electronic, I have a new long block in there, so I doubt it threw a rod, I took it over to automotion, Len will get it going for me.
