For Sale Diamond Axle
EKJ
Greeley Co.
Diamond axle housing for sale. Steering Diamond axle Setup with a 9.5 land cruiser third member and FJ 80 knuckle balls. Driver drop. 67” WMS toWMS. This is a brand new housing. Only used for mock up. The Knuckle balls are not fully welded yet. So the caster angle can be changed to meet your needs. The housing could also be shortened if its to wide for your build. Since the balls are just tacked in they could even be swapped out for a different style outer like a Dana 60. I have tacked some brackets to the housing but nothing is fully welded. I will clean up the tack welds before the buyer takes possession. Brian at Diamond axle can finish weld the the knuckle balls once the buyer confirms what they need. I have changed direction with my build and that’s the only reason I’m selling this axle. The housing will come with a stock 9.5 third member, FJ 80 spindles, FJ 80 knuckle balls, Knuckles, hubs, spindles, steering arms, rotors and calipers. The knuckles have the ABS hole so the Slee high steer arms will work with them. This is a nice housing that should work very well for some one! Asking $1050 located in Greeley CO. Can ship on buyers dime. Let me know if you have any questions. 720 two two six 1 1 90
