gmac1
Thanks for the further thoughts. That makes perfect sense.My suggestion above was focused on good value and use of money while getting superlative tools, but of course, it depends on what you plan to use it for. Obviously, at an extreme, there is no point getting a Starrett machinist indicator to do woodwork, but there are many in between situations. I tend to think of indicators as being realistically able to be used to 1/10 of a thou. And calipers to 1 thou. So, if you don't do machinist work to better than 1 thou all the time, realistically you don't need a Starrett. Like to check a brake rotor warpage for example, a HF should be plenty good enough if in reasonable condition. My point is that you may pay $30 for the new HF and sell it a year later for $5 and you had a crappy tool all along, or you could possibly buy a high quality used Starrett for $100 and sell it a year later for $90. I'll take the latter but of course that depends on budget constraints. Starretts and Mitutoyos are very expensive tools because they need to be for the jobs they are intended to do. Because they need to be precise, accurate, and reliable, because pros won't want to take a chance on ruining a $10,000 job to save $100 on the indicator. And if you're a pro you can deduct the tool from your taxes so there is a 50% discount already. But that also means they have excellent resale value.
x2I'd buy a used pro one from one of the big manufacturers like Starrett or Mitutoyo. You likely won't lose any money reselling it later on if kept in good nick.
