Determining Injector size... (2 Viewers)
Tigerstripe40
Utah
OK, so I picked up a Throttle body from a TBI chevy motor a few days ago, and I have rebuilt the unit.
I have NO idea what it came off of. There was a large pile of TBI units sitting in a pile at the wrecking lot. I just grabbed the one that looked the best (and honestly, it wasn't a very good unit).
I have no idea if it came from a 4.3, a 5.3 or a 5.7 liter enigne. I am pretty sure it came from one of those (and is not a big block TBI). When I pullled the Injectors out, the filter on teh bottom was a rust color. The electrical leads are red.
How do I determine what size injector I have?
Thanks!
I could be wrong but I believe that the 4.3, 5.0. and 5.7 all share the same injectors. Only the big block is differant.
Howell
It won't link directly but go to parts and accessories/tbi parts and they show them all at 500 cfm.
GM TBI Injectors are color coded. What the coding convention is, I cannot remember, but they are different for each displacement motor.
I can look tonight but you might find the info via a google search.
Ed
Only been reading some on TBI, no real experience. Take a look here:
GM TBI tuning tips
Looks like several possibilities.
These injectors are rated at the pressure used by the factory, about 13 PSI Application Throttle bore size Injector color code Flow rate Part #
2.8l v6 1-3/8" Black/White ??? GM 5235430
4.3L 1-13/16" Yellow/Blue ??? GM 5235203
5.0L 1-13/16" Green/White 40 lb/hr GM 5235279
5.7L pickup 1-13/16" Orange/Black 55 lb/hr GM 5235206
5.7L Cop Car 1-13/16" Yellow/Brown 65 lb/hr 17084327-ACR
Late big block pickup 2" Blue/Black 80 lb/hr GM 1708430 big block pickup 2" Dark Red/Dark Blue 90 lb/hr GM 5235231
From here: http://groups.msn.com/AutoTechsOnline/knownfixesforgm.msnw
