Desperate traveler needs help with A/C and blower motor on BJ74
Lethbridge AB
I have a 1989 JDM BJ74 (24v). My blower motor started making a ticking noise yesterday traveling through Arizona with the A/C cranked. Today it quit working after stopping for fuel. I tried an hour later and it worked again and was quiet.
I'm currently in southern Utah and have several more days of traveling before heading back to Canada. I would appreciate any help as or suggestions to keep the A/C going. Including any information on parts inter changeability with north American LC's
I do not know if this can help ...
I have already experienced this same kind of problem (stop, then work the next day or later)
Look at the blower motor breaker in the driver kick panel. You can do a reset by using a needle.
I no longer use the fastest speed on my BJ70 since several years because it blew my breaker afther 15 or 25 minutes of hard work.... Never had a problem with the other speeds.
This could be the first way to follow ... HTH
If you can can nail down what part you need I can ship replacement to you in the US pretty quickly.
Sounds like a blower motor. If the resistor goes you will lose the all but the high speed setting.
Ticking noise might be a leaf or some debris in the motor housing - easy to remove the motor and have a look.
Resistors are in stock.
Motors can be re-brushed easily enough.
~john
Hi BJ 71......if you see this drop me an email..."78toyota@gmail.com"
.....Charles
keep in mind that screw is not a Phillips screw head. It is a kind of ''star'' screw. I have lost a couple of minutes before I realize that the first time I take it appart. :o
Thanks for all the helpful responses but thanks to a poor cell phone provider my Internet access has been very limited.
Turns out it's the blower motor. Ticking turned to squealing but still intermittent. When it does quit I have been able to get it to get going again with a tap or two on the blower housing. So I assume that means the brushes are sticking.
Checked with cruiser outfitters on my way through salt lake yesterday but they didnt have one in stock. I should make it home by tonight or tmrw so hopefully it will hang in a little longer......
