Parting Out Denver: 1997 LX450 Black Partout No lockers (1 Viewer)
Just a review on the seller.
Got a reply on part availability within an hour, negotiation took even less time. Very reasonable pricing, had a tracking number within hours of payment. Parts should be here Saturday.
Update: parts arrived on time, and everything was packaged and wrapped up perfectly. Buy with confidence.
Hello,
Is the driver side trim moulding from your photo still available, ship to 94618
2010740
Hi, I am looking for both Catalytic Converters, they still available, please? if so, how much shipping to texas, 77494, please?
Thanks
Hello,
Is the driver side trim moulding from your photo still available, ship to 94618View attachment 2010740
Sold with running boards
Thanks
They are rusted and the truck failed emissions last time in Nov 2018 so I doubt they are good.
Do u have the front frame end sway bar mounts
Sold with the front axle
bump I need to get this thing stripped, people want the body and frame
Interested in upper/lower hatch. Any rust? Rear window seal good?
Photo of the lower dent?
Is this for local pickup because I don't trust shipping companies with large body panels.
Would need it shipped. No worries if you don't want to. Just starting to look for replacement pieces for mine as they have some dents from the PO and the gasket is starting to go. Figure its easier to just swap them out than it is to do the body work.
Hello. Wondering if you have the light bulb sockets and wiring for the front corner marker lights and the front turn signals? I’m looking for light bulb connector that clips into the housings with the wiring from the connector to where it clips into the main harness. Thanks.
The marker lights below the headlights? I do have both of the sub harnesses that have the socket for the light and the connector that goes to the main harness.
Yes those as well as the two for the front side / corner lights. Looking for the ## 4 and 5 sockets in the attached.
Bump need room
I have a 1997 Lexus Lx450 290k No Lockers
Engine suffered a rod through the oil pan. Still ran with oil pressure but knocked.
MORE PICTURES
Please bear with me, I travel a lot for work. I could be slow to get back to you with extra pictures or shipping quotes.
No shipping on large body panels
Known issues:
  • Drivers seat cushion tore up
  • Rear center bumper crushed
  • front bumper dented / scuffed
  • Tailgate has a dent at bottom under cladding
  • Drivers rear flare tabs broken
  • Passenger headlight glass broken
  • Antenna mast missing
  • Pass rear door has weird cracking on paint
  • Pass mirror Shaky
  • Center console won't stay closed, has some holes inside
Sold already:
  • Front axle complete brakes, radius arms / drag link/ tie rod
  • Steering box
  • Hood
  • Drivers Mirror
  • Air cleaner lid
  • Rear speaker covers
  • Driver's seat switch
  • Driver's door handle ( have more in different color)
  • pass mirror
  • Transmission shifter leather
  • Hub caps
  • Both Fenders
  • Drivers door (with window + motor+regulator + lock actuator)
  • Intake hose
  • wheels
  • Front seats
  • Steering wheel
  • Tail-lights
  • Drivers visor
  • Throttle cable bracket on motor
  • DriView attachment 1949303
Hey buddy. Looking for headlight and mirrors and a ac control
Sorry guys I didnt see these posts.
Hi do you still have the running boards, front bumper & headlights?
I have the running boards that have the chrome strip. 100 for the set
Bumper is gone
Only headlight is a pass side and the glass is not perfect
Only have pass headlight that is not perfect
The AC controls? I'm assuming you have automatic ac? I have one
Looking for the center console piece. Shipping would be to 77056. Still available?
Also would be interested in the shift pattern plate and the shift knob if in good shape.
Center piece sold, shifter sold, shift pattern available for 25 shipped
Looking for the rear carpet (trunk) in beige
Threw carpet away
Looking to see if you have the sliding yoke assy for the steering? It attaches the steering column to the P/S gearbox. PM me if you do thanks!
