craigslist Decent fj40 in Stl on Craigslist for 3k
http://stlouis.craigslist.org/car/757397478.html
I ran down to take a look at it.
As you read, the engine hasn’t run, I tried rolling it in 3rd to get it to turn, then hooked up a jump starter, lights worked, the motor appears to be frozen up. It wouldn’t budge. Mileage is 28k (+or minus 100k) Valve cover leaks, battery was dated 97, radiator was full, carb was dry. Air filter was brand new, spark plugs are new. Electrical under the hood is complete, doesn’t look weathered or cracked up too much. Transfer case felt good. 3 on the tree shifted smooth. Steering box had obvious leak, front axles and undercarriage looked good. Frame only had surface rust. No pitting rust at all underneath.
The interior is in nice shape. The rust on the front floor boards is minimal surface rust. The rear floor is in excellent condition. All Seats have been recovered and look good. Dash pad in good shape no cracks. Headliner is excellent. No roll bar. Original paint. No rust above rear wheels. No rust inside doors. (front or rear) Rear sill and cross members outstanding. Minimal surface rust under tub in rear. Bondo job under door sills. (typical location) Bondo on the corners. Steering wheel has minimal play, front tires have obvious uneven wear.
Drip rail on front of cab is disconnected for about 1.5 '. Can easily be repaired.
If you have any other questions, PM me, I went over it for about an hour.
Sold, lasted 4 hours on CL. Good Deal?
