Dead battery (again) 2006 LX. Options?
So Cal
2006 LX with 160k 156k miles on it.
Noticed there's a spate of electrical issue posts here lately, including mine, which I'm hoping is a battery at the end of its useful life.
If it is the battery, 1. Is this normal battery life expectancy (see notes below). 2. What battery does the Hive recommend for longevity and reliability, without being insanely overpriced (cost/benefit analysis). Go with the Costco Interstate AGM battery (it's not the "right" size, though)?? My plan is to gift my built '04 4Runner to my kid and to repo this LX from the wifeand get her a RAV4, so I want to have some peace of mind that this LX won't die in the middle of nowhere and be as reliable as my 4Runner is.
Installed Costo/Interstate battery in Sept. 2020 at 130,000 miles.
Previous battery was Sears in 2015 at ~95k miles.
My 2006 LX has 160k miles, and is on it's third alternator (Toyota reman) as of Jan 2022 at 138k miles.
It's on its 3rd alternator (Toyota reman) as of Jan 2022 at 138k miles. I'd like to think it'll last longer than 3 yrs.
The 2nd alternator was installed June 2012 at 67k miles
Thanks in advance for any advice and recommendations offered.
Update: I realized the negative terminal connection was a little loose. The thick felt terminal protector that I put under the positive/negative conections were preventing the negative terminal from sitting lower and getting a good grip on the terminal, so I removed that felt thing.
Photo for attention.
3 alternators doesn't sound right. My 05 with similar mileage is still on the original alternator. Does the battery die if it sits a few days to a week? Check for parasitic draw with a multimeter. I had a parasitic draw I traced to the radio fuse and ultimately the 6 cd changer connection buried under the center console (my CD player didn't work anyways).
Hard to go wrong with a 27F from Costco if you are a member there.
I agree that being on my 3rd alternator (all OEM) on a mall cruiser LX is weird. Could very well be that the local trusted independent Toyota / Lexus shop where used to go operates a little too quick and dirty for my likes. I think he got spoiled with all the rich beach people (which I'm not) never questioning his work, which I started to do a few yrs ago. Checked for parasitic draw earlier today by disconnecting the negative terminal, and couldn't find any, with the LX both locked and unlocked via the key FOB. Could be that my neighbor didn't have the meter set right, but in his defense we did use his, and my, meters, so I should probably look for a write-up on doing that to ensure it's being doe the correct way. BTW I have the OEM disc changer in the center console, too.
Will probably be getting another 27F from Costco tomorrow. Was debating on getting their 24F AGM battery but will likely pass on the AGM.
5 years sounds about right. You can take it over to auto zone and get a free battery test. I usually don’t notice my batteries going bad until the beginning of winter.
Replace the battery and make certain it's fully charged before you swap it out.
That "felt thing" is just a mat to absorb any battery electrolyte that makes it way past the post to keep it from corroding the terminal or your cables. It the connection was loose, it's not from the felt, it's from the improper torque of the terminal bolt.
I can't help with the multiple alternators except to say that it can be the battery killing the alt, or they were all cheap refurbs where they get cleaned up and painted but never actually refurbished. That's one of the reasons you want to fully charge the battery before you install, it gives you a better chance to troubleshoot.
HF just released a new amp draw tool for fuse boxes, I have not used it but will pick one up next time I'm in the store. It might help you look for amp draws that are pulling down the battery over time.
How long is the vehicle sitting between use? That's fairly low mileage, so I would guess it sits a lot. FLA batteries discharge on their own at rest. If any of my vehicles are going to sit for more than a couple of days I leave the battery on a float charger. AGM batteries are more tolerant of being discharged heavily but you will need a proper alternator (or mod) to make sure the battery is getting charged properly.
Refurb alternators are a crapshoot.
Got a new 27F at Costco this AM. Made this month and it tested at 12.58V and is on a 2AMP trickle charge for a few hours and will put it in later today.
The LX is driven by my wife, and yes it does sit a lot. She works part time so it gets driven three days a week about 20 miles round-trip in stop-n' go traffic, and maybe a few short errands within our bubble in between.
Google University educated me the past couple of days and I learned the basics on how to use a multimeter...funny thing is that most of what I saw on YouTube were auto mechanic guys doing electrical tests on 100s lol! Anywho, alternator seems fine as battery jumps to 14+V after starting the LX.
I'll go back and look deeeper for parasitic draw once the new battery is in. (UPDATE: None found.)
Thanks All!
