I am wrapping up a long-running project and have found that my efforts have pointed my rear pinion up vs the stock config of parallel to the ground.
To be exact, I have 10* of difference between the pinion angle and the output shaft on the t-case.
Can I install a 6* shim to close the gap to 4* and run the stock driveshaft? Or will 4* difference still require a DC shaft to prevent vibration? The shaft ultimately will be ~20" long.
On the front of the vehicle I have 3* of different b/n the pinion and the t-case output shaft without any trouble, but that d-shaft isn't generally doing 2500 RPM's
Appreciate any thoughts/experience with this one.
