My front brake rotors are fried ('warped') and I need a front brake upgrade before I head south to Moab next April and for the 2011 wheeling season. I am looking for better heat tolerance, since my problem seems to be overheated front brakes from the long mountain descents into the Fraser canyon and the descents around Moab and Canyon Lands. Often I get insufficient engine braking due to the wide 3rd to 4th gearing gap on the H55 transmission.
I looked into the 4 Runner calliper and master cylinder upgrade for the BJ74, but found mixed reviews (e.g. Gary Telford). It looks like the leverage gained from the larger 4 Runner callipers (results in more pedal travel), is taken away by the larger master cylinder that is part of the recommended conversion. Although, the larger 4 Runner pads would be better at dissipating heat, slotted rotors are also good at shedding the hot gasses underneath the brake pads.
So after some research I ordered a set of DBA 4000 slotted rotors (made in Australia) and PBR ceramic brake pads and stainless steel brake lines. I looked at Brembo rotors, but they do not offer a slotted rotor to fit the 60/70 axle. The ceramic pads are extremely heat tolerant and produce little dust, but are reported to wear the rotors a little faster than on the OEM set-up. The stainless steel wrapped brake lines are better at resisting flexing under hard braking – the 20-year rubber ones on there now are due for replacement. The reports are the slots on the rotors do not pack up with mud, but I will keep an eye on that.
I have a bunch of other stuff to do before I get to the brakes, but I will file a report after Moab if this was a worthwhile upgrade to the marginal brakes on these rigs.
Merry Christmas
Merry Christmas
