Dash lights and tirn sigmals quit
Las Vegas, NV
Yesterday I pulled my instrument cluster to clean out the dirt from inside it and also replaced the speedo cable. After re installing it I found I now have no dash lights or turn signals. These worked prior to the job. All other lights and gauges seem to work. Checked fuses and are ok. Is there something I'm missing, a ground or another fuse? Cheers
Ps I have a 3 post relay wires to the left front turn signal that has corrosion on it. Is it possibly the relay for my lighting issue or is the turn signal relay located somewhere else on my 1987 HJ75? Thanks
Ok i now have dash lights, reverse lights but i don't have hazard or turn signal lights. Ill clean the hazard and see if that helps. VERY OPEN TO SUGGESTIONS
