Dash board
To remove the instrument panel, gently pull the black cluster panel finish towards you. It is fastened via clips and shouldn't break. The black panel houses the dimmer switch which can either be disconnected or just swung out of the way.
Unscrew the 2 black screws at the top and bottom corners of the instrument panel. Next, loosen the 2 bigger gold captive screws at the bottom of the inst. panel. Once loose, gently pull the panel towards you. If it doesn't move freely towards you, you need to further loosen the screws as they are connected to wire harness connectors behind the inst. panel.
Remove the glass inst. panel cover and top of the steering column cover. (thx Loud) You should now be able to slide the inst. panel to the left of the steering wheel.
https://forum.ih8mud.com/100-series-cruisers/409313-led-instrument-panel-gauge-cluster.html
