Damn Birf
Whitinsville, MA
In preparation for a disk brake swap I'm pulling some FJ62 knuckles apart. Now the problem that I am having is the birf won't come off the inner axle. Is there an easy way to pull it off. I tried hammering it off with a drift but no luck to far. Its out of the axle and the housing is long gone so the pipe trick doesn't seem like an option. I just don't want to damage the joint. Does anyone have any suggestions?
take a pipe longer than the inner and a little larger diameter, put the inner in it(vertical) and bang it on the floor hard. It should pop right off.
i lay the inner on a 4x4, stand on it, and put a big brass drift against innerbirf race and they pop off with one or two whacks....
x2, except I just lay in on the ground and smash the bell with a sledge...away from the inner axle. Bobby longfield does it the same way and taught me that trick. Course...he works with cryo...
