Wife backed up and hit a tree hard w/ drivers mirror.
The camera, reverse tilt and folding still work. The entire mirror is now slightly loose and I can move it around a little, not the bracket that mounts to the door but the main mirror assembly, the part that folds. From the way I can move/flex it I am guessing that the main plastic piece inside the mirror is cracked. Anyone have experience w/ this situation. Seems like I have three options:
1. Replace entire mirror assembly for $900, not really wanting to do this.
2. Replace Retractor Assy (Part #87966-60J80) and hope this is the part that is broken, the piece that holds the actual mirror. Anyone know if this part should fix it? Image below.
3. Open up the mirror and try and epoxy whatever is broken
Also, if I go w/ option #2 do I need to pull door panel and entire mirror to replace internal piece or can it be done with the mirror on the door?
Anyone have tips on mirror disassembly? I have the FSM and it looks like removing the outer cover is a PITA
