For Sale Cummins repowered 1979 Dodge W200 4 door
Unfinished resto-mod. 80% complete. The listing below states what is included in the sale.
-1992 CTD front clip
-1992 CTD front doors
-Frame has been squared, boxed, jig holes filled
-Steering gear mount reinforced
-JCWhitney weatherstrip kit
-Energy Suspension cab mounts
-Custom made inner fender liners
Front Axle
-ARB RD21 airlocker
-4.88 r&p
-8' braided ARB airline
-new bearings and seals
-new brakes
-braided caliper lines
-Lube Locker gasket
-Kryptonite diff. cover
-NWFabworks High Steer
-ARP stud kit
-1410 straps
Rear Axle
-ARB RD35 airlocker
-4.88 r&p
-20' braided ARB airline
-new brakes
-Lube Locker gasket
-1410 straps
-Missouri Offroad Axle Truss
-Rear brake disc conversion - not installed
Motor - 1992 CTD 130,000 miles
-Killer dowel pin killed
-New front main seal
-New rear main seal
-New valve cover gaskets
-Valves adjusted
-2nd Gen. low pressure lift pump
-Bully Dog fuel pin
-New HX35 Turbo
-4" ceramic coated downpipe
-Horton 2nd Gen. Fan
Transmission - 1992 A518
-2nd Gen. flexplate
-TCI Torque converter
-Hughes Performance shift kit
Fuel tanks
-2- 34 gallon Ramcharger tanks
-3/8" pickups
-Pollak Motorized Fuel Tank Selector Valve
-Jaz Fuel Cell fill
Transfer Cases
-NP205 out of '92 CTD, shift rails Machined for triple stick
-NP203 out of '79 W200
-Both new seals
-PolyBushing transfer case mounts
-billows vent
-NWFabworks - Billet kit
- 32 spline input gear
- doubler kit
- side mount kit
-Air cylinder shift components
Front Driveline
-High Angle Long slip 3" tube
-1410 ujoints with straps
Rear Driveline - 1992 CTD
-High Angle E-Brake
-balanced
-new carrier bearing
Steering
-Borgeson Steering Shaft
-West Texas Offroad Hydro Assist
-tapped steering gear
-Sauer/Danfoos Power Steering Pump with Stirling Relief Valve
Rims
-Stazworks Double Beadlocks 17x11
-Powertank Monster Valves
-DynaBead Valve Stems
Seats
-PRP Daily Drivers Xtra wide
- lumbar support
- sliders
-Crow V-Harness with pads
Suspension
Front
-SkyJacker D600S 4" leaf springs
-SkyJacker DA60 Extreme shocks
-Energy Suspension bushings
-5/8" greasable bolt
-2" shackle extension
-1 1/2" front spring frame bushing upgrade
-ubolts flipped
-grade 8 bolts, nut, washers
-Timbren A170-55 with cans
Rear
-SkyJacker DR40S 4" leaf springs
-SkyJacker DA40 Extreme shocks
-4"shackle flip
-ubolts flipped
-Timbren A535-55 with cans
Misc.-
-Vanco Hydroboost
-Haldex air compressor with relief valve
-Grade 8 Fasteners throughout
-Tuffy Series 2 Security Console with armrest and rear drink holder
-One off front bumper with 7.5 gallon air tank
-One off rock sliders
-One off roof rack
-One off tubed bed
-One off skid plates
-One off rear bumper
-One off cage and dash
-One off crossmembers for transmission and transfer cases
-One off dual battery box
-Conversion van rear folddown seat
-4 LightForce Blitz lights
-4 LightForce Stryker Lights
-TMax 12000 winch
Second Skin Audio soundproofing material
-3 Shop Pack Damplifier Pro
-10 sheets Luxury Liner Pro
-2 gallons Sprayable Spectrum Vibration Polymer
-3 Second Skin Contact Spray Adhesive
-1 undercoat spray gun
-150' roll foil insulation tape
-2 wooden hand rollers
This project is 80% complete. A minimum of the following needs to be addressed-
-Fuel and brake plumbing.
-Wiring
-Gauges
-Tires
-HVAC (if you want it)
This project is undrivable and must be trailered.
That's a helluva list and I'm certain I've forgotten something.
Front Axle
-ARB RD21 airlocker
-4.88 r&p
-new brakes
-Lube Locker gasket
-ARP stud kit
-1410 straps
Rear Axle
-ARB RD35 airlocker
-4.88 r&p
-new brakes
-Lube Locker gasket
-1410 straps
-New rear main seal
-Valves adjusted
-Bully Dog fuel pin
-New HX35 Turbo
-2nd Gen. flexplate
Fuel tanks
-3/8" pickups
-Jaz Fuel Cell fill
Transfer Cases
-Both new seals
-billows vent
- doubler kit
- side mount kit
Front Driveline
-High Angle E-Brake
-balanced
Steering
Rims
Seats
- lumbar support
- sliders
Suspension
Front
-ubolts flipped
Rear
-4"shackle flip
-ubolts flipped
Misc.-
-Vanco Hydroboost
-One off roof rack
-One off tubed bed
-TMax 12000 winch
-Wiring
-Gauges
-Tires
I have receipts for over $38,000. $12,000 I'm willing to entertain offers and trades. Clear title in hand. Truck is located in Spearfish, SD. I am not parting out. Please, serious inquiries only. If you are interested contact me via pm.
pictures - http://s1144.beta.photobucket.com/user/jensenkennels/library/Dodge
PM Sent. Thank you!
