- Location
- United States
Cummins B3.3T
85hp - 215 ft-lbs
I have two engines available in the B3.3 series at this time:
(1) Brand New - $5,500 OBRO
(1) 35hrs - basically "new" - $4800
If you have been searching for a 3.3 for a diesel swap you know how hard these are to find!
Significantly less noise and vibration than the Cummins 4BT 3.9L, and almost 200lbs lighter... Please contact me for shipping quotes, swap questions and any other info on these engines. These are fully inspected, palletized and ready to ship. No CORE Charge.
DODGE CUMMINS 5.9L
ISB325
$4,500 OBRO - DIESEL ENGINE ASSEMBLY - TAKE OUT CONDITION WITH UNDER 60,000 MILES. WE HAVE SEVERAL CUMMINS ENGINES (B3.3T, 4BT, 6BT, ISB325) IN STOCK AND CAN SUPPLY ENGINES FOR MULTIPLE APPLICATIONS - MODEL YEARS INCLUDING AUTOMATIC AND STANDARD TRANSMISSIONS. THERE IS NO CORE CHARGE (YOU DON'T NEED TO SEND YOUR OLD ENGINE BACK), FUEL SYSTEM (INJECTORS, HIGH PRESSURE PUMP), WATER PUMP, ENGINE ROTATING ASSEMBLY. ALL ENGINES ARE PULLED FROM DISMANTLED VECHILES THAT HAVE BEEN INVOLVED IN REAR OR SIDE IMPACTS. WE WILL NOT SUPPLY ROLL OVERS. ENGINES ARE TESTED FOR COMPRESSION, ELECTRICAL CODES.
This unit does not include PS Pump, Alternator, A/C pump, or Turbo.
PLEASE Email FOR MORE INFORMATION.
Located: Pompano FL 33064
85hp - 215 ft-lbs
DODGE CUMMINS 5.9L
ISB325
