cummins 6AT
I've got an original cummins 6AT for sale. Bought it a few years back for the fj60 but decided to finish another project needing funds. Around 160k(miles) and ran strong before pulled. Fully mechanical, just 1 wire hookup for glow plugs, bolts up to chevy bellhousing, comes with bosch high output alternator,and water separator. looking for $1500. contact mike at 360-223-0914. located in anacortes washington.
Now that is a motor. Bump
Just an FYI.. This motor should be a bolt up to any chevy to LC adapter I have ridden in two different 6AT powered cruisers, fj40 and FJ60 and both felt just as powerful or more so than any 2f powered rig I've driven and I don't think much lift is necessary.
Does it have a flywheel for a standard clutch?
Yes it does have a flywheel for a standard clutch. It is super burly and could be machined to fit just about any clutch within reason. Thing probably weighs about 25lb:) When I bought this engine I had done research and found that this is a very smooth setup and gets anywhere from 28-32 mpg while sustaining decent power. This would be sweet in a cruiser:)
