Cummins 4BT - NV4500HD - 242DHD T-case - Dana 60 - Corp 14 bolt
Nice Side of the Wasatch Range
This is bulletproof 1 Ton drivetrain combined with a Cummins 4BT! Want to re-power that rig to run biodiesel or crawl without breaking? This is the complete package: Cummins 4BT with so little hours the paint hasn't even burned of the exhaust manifold, cast iron NV4500 HD transmission with 242DHD T-case out of 1 ton Dodge diesel truck with only 59k miles, adapter plate to bolt the bell housing up to the 4BT, flywheel and clutch from Dodge also. Drivers drop Dana 60 Ford Kingpin front axle, Corp 14 bolt rear axle. Will not separate - all or none! Price is firm, if I don't sell I will just keep for my FJ55 project. Right now I need a house more than a diesel.
$5000.00
Located in South Weber, Utah
I would prefer you pick it up to haul it home, but if you must freight then you acquire the trucking company and assume all risk and liability once it leaves my place.
NEW PRICES: I need this stuff GONE!
New prices:
I would like the 4BT and trans/t-case, adapter, flywheel, etc. to stay together:
$3500
Dana 60 Front: $1000/offer
Corp 14 bolt rear $150
Someone step up to the pump!
