For Sale Cummins 3.9L 4BT P-Pump HY35 Turbo 75K miles $3100
For Sale - 1995 Cummins 130hp 3.9L 4BT P-Pump HY35 Turbo
SOLD
This engine was from my daily driver box truck and has 75,700 miles
It is in perfect running condition, and has the ultra-rare very desirable Bosch P7100 Injection Pump.
The engine was pulled 3.5 weeks ago - it was steam cleaned, repaint with Cummins OEM engine paint, new exhaust & turbo gasket, new valve cover seals, gear housing seals, "killer dowel pin" fix performed while the engine was out, New fuel filter, new oil filter, new turbo supply line, new belt, & new belt tensioner.
As you can see from the pics and the valves it is in incredible condition. You will be hard pressed to find another P-Pump 3.9L 4BT in this condition!
Includes:
Cummins 3.9L 4BT engine - 75,700 miles
Cummins - Ford Flywheel for manual trans
Cummins- Ford Bellhousing Adapter
Ford T-19 4speed transmission 75,700 miles
Starter, Alternator, Power Steering Hyd pump
HY35 Turbo & 4in MBRP downpipe
Factory Dodge Intercooler and Fluid filled engine mounts
The engine is complete From Fan to Transmission, just bolt in a clutch!
Located:
Biddeford Maine 04005
(I can help with shipping/palletizing)
Call or TXT - TWO ZERO SEVEN - 702 - ZERO ZERO ONE ONE
Thx.
