For a crossmember/support running under the Toybox to a Toyota mini-truck t-case mount will 1" OD .120 wall DOM be strong enough?
Poser said:Will this only be supporting the toybox and mini case, or will it be supporting the whole rear section of drivetrain?
IanB said:Toybox and split case, I have the 76 bellhousing bolted up to the 85 tranny, so I was going to use the mount point under the toybox versus the one under the tranny as its closer to the split case.
How about 1.5" OD .250 wall DOM?
fj40charles said:I would lean toward 1.75" or 2" .250 wall dom or 1.75" or 2" square .250 wall tubing. Just my 2 cents.
Wouldn't a lot of force be rotational from torque? That would put the force purpendicular to the tube.isotel said:I used Square Tubing on mine.. My Thought is that the Forces on a crossmember are mostly along parallel axis with the tube,
Mine is 1.5" 3/16 wall Square, no issues thus far, But its not Tested hard yet!
I was thinking of it as an inverted truss, with the t-case mount as the cross piece.IanB said:I think the force is up and down, so perpendicular to the long axis of the tube. Ideally you allow a little twist for torque, hence the rubber mounts, but you want to stop the up and down play possible with the lengthened drivetrain due to the Toybox, the split case now has a lot of leverage on the last mounts, which are the engine mounts on the bell housing.
So, it occurred to me that if the tube was bent down in the middle (which is necesary to clear the t-case front output flange) then down force would get translated into some tension and up force would get translaterd into some compression (anyone who actually knows WTF they are talking about is more than welcome to interrupt me at this point...) especially if the load on the middle of the tube (the Toybox) is at the apex (low point) of the bend. Theres no more down to go so it becomes a tension load along the axis of the tube to the frame mounts, and vice versa on upwards loads?
Am I high?
rusty_tlc said:I was thinking of it as an inverted truss, with the t-case mount as the cross piece.
\_/ rather than /-\
Trusses work best for loads in compression or up in this case.
Maybe something like \|_|/ would help with the down loads and keep the size of the tubing down?
BTW with the additional torque from the low gearing I wouldn't discount rotational forces.
But what do I know?![]()
Makes sense and sounds like a good design.IanB said:Due to clearance on the t-case it has to be an inverted truss, like frame\___/frame. 60wag was looking at it last night and thinks the 1.5" .250 wall DOM will be plenty strong, this is after all just a brace for the tcase and toybox. The tranny is bolted to a '76 bellhousing which has its own brand new mounts.
As far as torsional forces I am not discounting them, but Uncle Ben said there should be a little (very little) room for twist. So I am using the rubber t-case mount from a toyota mini truck and I will be mounting the crossmember to the frame with spring bushings. So the whole drivetrain will be mounted to the frame with rubber paded mounts. Does that make sense?
