Crazy t-case issues
New Kent, VA
Ok, heres the deal. Im switching the vacuum solenoids that engage and disengage the 4wd with MAC valves like people on this board have done. I have the hoses all set up like they are supposed to be (manifold to fitting 1, tcase to fitting 2), i checked the solenoids to see if the work (they do), and it wont work. In fact, i keep blowing fuses like crazy. So i officially have no idea whats goin on. Any one who has done this mod please gimme some help here.
Also, i wanna go wheeling tommorow so i was just gonna switch the hoses up, but i couldnt get it to work. If i connect the line from the manifold to one side of the diapraghm ie to one of the 2 hoses that runs to the tcase and leave the other open, shouldnt it go into 4wd? Because its not. :mad:
Help.
Gratuitous bump.
Im wondering if the new valves pull more amps than the old ones did. Im gonna crawl underneath and find out if i have a mystery vacuum leak somewhere too.
Its all good now. Turns out i think there was a blockage in the hose. I got it to shift into 4wd with a vacuum line straight from the manifold (i guess i unblocked it with the force) and then rehooked up the solenoids. I think i was shorting it by having all the wires dangling out and touching each other (im a retard sometimes) and once i put heat shrink on em it worked fine.
Wheeling in T-Minus 1 hour.
