@FJ40Jim (Andy all you other experienced guys)
This is the first time I’m a getting into a motor or rebuild. I’m trying to learn everything I can and do most of the work myself.
This is going to stray a bit from the title of this thread... but I had a few more question that I thought of.
When I pulled the motor apart, I used some snap gauges and calipers to measure the cylinders and pistons. (I have some experience with precision measurements but have done little on note measurements).
I was pleasantly surprised because the cylinders we measuring quite round and very little taper and toward the tight end of spec. I measured in 6 spots (3 thrust and three axial measurements). I didn’t write my measurements down bc I was just doing it for my own experience and was going to rely on the engine shop. I then took the motor into a recommended machine shop for cleaning, magniflux and inspection. The shop said that the notes were out of round and tapered by .001-.002”. Possible that I measured wrong..... I asked the builder for his measurements and he just said it was .001-.002 out... he did not give me the individual measurements. (I didn’t really like that but I’m new to this... that may be normal). Before deciding what kind of $ to put into this I am considering pulling the motor from the shop and doing more inspection on my own prior to machining etc.
I want to make sure I understand the specs... the fsm shows wear limits and standard bore dims.
1. It does not mention taper or out of round... what limits should be used for that?
2. WRT wear limit of .008” (seems like a very large limit), does that mean that as long as all of 6 measurements from each cylinder are less than the upper bore diameter limit + .008, that cylinder is good? I’m guessing it is more complex than that.
It also instructs to measure/calculate piston clearance. The fsm seems to imply that you subtract piston diameter from the axial diameter of the cylinder.
3. Is that the only measurement position (on the cylinder) that is considered for piston to cylinder clearance?
Also found this other resource
http://vintage.mitchell1.com/PClubData/chassis/enis76/V2I765295.pdf that calls out the same cylinder ware limit but also calls out taper and dif between cylinders. (It may be in the fsm as well and I just missed it). Are those limits accurate?
Maybe I’m overthinking all of this.....
Thx so much. I have really enjoyed learning about motors!
