The door switch that should be lighting up the lamp on the door and lights under the steps seems to not be making contact when the plunger is fully sprung open. I can mess with it and apply some pressure to get everything to light up but it won’t stay that way. I’d like to remove the switch and see if I can clean up excess grease. Problem is, I can’t seem to pull the switch out of the b-pillar enough to disengage the connection. And I’m worried if I pull too hard, the female end will be impossible to get to for reinstallation. Anyone come across this before?
