Coolant bypass hose to top of radiator (1 Viewer)
San Diego
Hey everyone,
I am looking for the inside diameter of the thin coolant bypass hose that connects to top of radiator via small nipple.
It must have another name because I've searched for it and can't find it. If anyone knows the gates brand part number that would help too.
Appreciate any help. Thanks
Water bypass #3
16267-66020
8mm sounds right, but don't quote me on that.
If you're asking about the perennial PITA nipple that breaks off, ruining a completely serviceable radiator, the body OD is nominally Ø8-mm (Ø 0.315-in); the locking flange diameter is Ø 9.25-mm (Ø 0.365-in).
This means that while a Ø5/16-in ID hose (Ø 0.3125-in) will ideally fit the body, stretching it to fit over the locking flange might be a step too far (depending on the wall thickness) and result in plastic deformation, which in turn will cause the connection to leak, no matter how tight the clamp is. You're better off using a metric hose, or better yet, just buy the OEM hose.
Hey everyone,
your talking about the black over flow hose that connects the goose neck male spout to the Expansion Tank bottle right ?
need to know what year your 80 series id first ?
help us help you
post always all your truck specs
thanks
