Connectors
Texas
P0441 code. Found rodents had chewed two wires. Cannot locate one of the plugs. They are identical except location of jetway. 11149 and 11156 are embossed on plugs
Order 4x 82998-12440
About $7 each on the discount parts sites. Don't pay the scammers $15 on ebay like some of the listings.
They are the toyota repair wires that come with terminal and rubber gasket. You'd depin your wires from those connectors then splice the wires to the harness connecting the appropriate wires to their spots on the solenoids.
Those connectors look fine to me.
If you need help getting the wires depinned I can attempt to take some pictures of mine and the tools I use.
Also if you want to replace the chewed foam block it is 12601-38020
Also for future reference if you do need to order the connector housings you'd put 90980- in front of the five-digit number you located to order them in toyota's system. They will come bare without wires though.. wouldn't do much good in your case.
Hi Mud- I have run into a similar problem. Is there a harness assembly available or is replacing the individual pins/wires the only option?
There is but it's basically the whole engine harness, which would actually be harder to install than just doing the repair.
If you don't want to tackle it order the listed parts and bring it to a decent auto repair shop. Should be a super simple job for them.
Thanks!!
